Problem
08/10/2023 at 10:04 • 0 commentsI soldered all the parts to a universal soldering iron. All wiring remains the same as on the breadboard. The soldering iron is 15X10 cm. There was a complication on the board, a short circuit! The Arduino burned up. I am currently waiting for a new one.
Base
08/08/2023 at 14:04 • 0 commentsI don't have many photos for this update because I'm writing it backwards. I started with the first prototype on the breadboard, I fitted it with the components listed in the parts list. Then I started writing code. I wrote all the code in the Arduino IDE. ChatGPT and Google Bard helped me with the code. The code is quite simple, and the biggest complication in the code is the Pong game, which was tricky to incorporate into the code (well, for a beginner :)). Otherwise there were no major complications.
