b800es_left_control_mount_a.stl
Mount for Gaggiuino screen. Part A attaches to the chassis using the original mounting bosses and original screws
Standard Tesselated Geometry -
220.79 kB -
08/07/2023 at 06:22
Download
b800es_left_control_mount_d.stl
Mount for Gaggiuino screen. Part D attaches to parts Part C and B with M3x16 socket head screws and M3 threaded inserts
228.99 kB -
08/07/2023 at 06:22
Download
b800es_left_control_mount_b.stl
Mount for Gaggiuino screen. Part B attaches to Part A using a M4x25mm socket head screw and nut. This does not require any modification of the chassis and uses the original holes for the buttons
265.12 kB -
08/07/2023 at 06:22
Download
b800es_left_control_mount_c.stl
Mount for Gaggiuino screen. Part C is a spacer between the front plate (part D) and the back plate (part B)
103.21 kB -
08/07/2023 at 06:22
Download
b800es_right_control_mount_b.stl
Mount for power and steam switches. Part B attaches to Part A using M4x25mm socket head screws and nuts. This does not require any modification of the chassis and uses the original holes for the buttons
339.14 kB -
08/07/2023 at 06:10
Download
b800es_right_control_mount_c.stl
Mount for power and steam switches. Part C contains the power and steam rocker switches, and attaches to Part B with M3x16 socket head screws and M3 threaded inserts
180.16 kB -
08/07/2023 at 06:10
Download
b800es_right_control_mount_a.stl
Mount for power and steam switches. Part A attaches to the chassis using the original mounting bosses and original screws
244.61 kB -
08/07/2023 at 06:10
Download
b800es_power_mount.stl
Mount for SSR, time delay cutoff relay, and terminal block. This screws onto the mounting bosses for the original electronics control board
198.23 kB -
08/07/2023 at 06:08
Download
mount_box.stl
Mounting box for Gaggiuino electronics. Mates with a clear project box lid to provide better mains isolation
3.24 MB -
08/07/2023 at 06:08
Download
