I made a circuit that provided the H-Bridge functionality to the linear actuator, by using 2 relay modules. I connected the together using the following schematic and connected their signal pins to the Arduino's IO pins.
![](https://cdn.hackaday.io/images/5732921691855785825.jpg)
Programmed the Arduino to interpret Channel 4's inputs as the signal for moving the snowplow arm by sending the D11 or D12 digital IO signal to the relay modules. I hope that a circuit like this one is able to help anyone else having the same design problems in the future.
