Raspberry SX
Cyberdesck based on old Commodore 64 SX based on Raspberry Pi.
It uses a Raspberry Pi 4 with Wifi and 8Gb memory. There is an SSD attached to it using one of the USB 3.0 ports. The other USB 3.0 is used to attach a USB hub. On the USB 2.0 port is a keyboard attached and the other USB 2.0 port is used for the touch screen. It is powered by a powerbank, which is charged using a power supply. There is much place left in the cyberdeck to add other measuring instruments or a Pi modules cluster.
It is open-source and you can adapt the design as you wish as long as you send me a pictures of your usage with a explanation of usage.
And when we meet in person, you can also buy me a beer.
More information is found under the docs in the github project.
Rich text editor
Cesar Miquel wrote 08/16/2023 at 16:26 point
It's in the sidebar but here it is in case you still don't see it: https://github.com/cryptable/raspberry-sx
Mark McGookin wrote 08/15/2023 at 19:47 point
I must be dumb, but I can’t find a link to the GitHub project
chatgptlogin11 wrote 08/13/2023 at 05:29 point
Must visit https://chatgptlogin.art/ for more
chatgptlogin11 wrote 08/13/2023 at 05:28 point
Great Job also visit https://chatgptlogn.com/
Tom Nardi wrote 08/13/2023 at 04:15 point
Like the idea of printing the case rather than having to find and gut a real "luggable" from the time period.
David Tillemans wrote 08/13/2023 at 17:29 point
Yes, I thought so too and you can adapt the design to your need if you want to use the interior to store other measuring circuits.
I does take a week to print though.
