It uses a Raspberry Pi 4 with Wifi and 8Gb memory. There is an SSD attached to it using one of the USB 3.0 ports. The other USB 3.0 is used to attach a USB hub. On the USB 2.0 port is a keyboard attached and the other USB 2.0 port is used for the touch screen. It is powered by a powerbank, which is charged using a power supply. There is much place left in the cyberdeck to add other measuring instruments or a Pi modules cluster.
It is open-source and you can adapt the design as you wish as long as you send me a pictures of your usage with a explanation of usage.
And when we meet in person, you can also buy me a beer.
More information is found under the docs in the github project.
It's in the sidebar but here it is in case you still don't see it: https://github.com/cryptable/raspberry-sx
