I thought I would participate in the 1kB challenge with this project.
Turns out, a bf Interpreter can be written in 1kB for the Super NES.
The Interpreter as is will interprete a program and display the Output. There is also support for writing programs. The only Instruction that does nothing is ','
I finished the programming Mode; now the Interpreter also supports writing a new Program.
In order to get some more free space, I got around compressing the GFX Data, improving memory usage by about 27% (from 512 Bytes down to 372 for packed data and table)
I dont think I will be able to squeeze in an Input method for the ',' instruction, there is no more space available.
This is also as far as I will take it with the SNESf1k Interpreter, the memory limitation does not allow for any more than this.
