I ordered GDEY042T81-FT02 earlier in September and didn't expect it to ship for ages, but they've arrived in just 2 weeks! I also ordered the DESPI-C03 development board also made by Good Display to ease development.
It's important to note the this display uses the SSD1683 driver instead of the UC8176. With luck, I can setup the tool chain such that the code can compile for GDEW042T2 or GDEY042T81 with a single compiler flag. I'm in the process of refactoring the code to follow the separation of concerns paradigm to make this a reality.
Also, the GDEY042T2-FT02 specification page claims the touch IC is FT6336, but the actual part has both FT6206 and FT6336 labels. From the existing libraries I've found, there shouldn't be too big a difference.
With the arrival of new displays and the portable power solution, I have quite a bit of firmware to write with all the hardware changes:
- FT6XX6 touchscreen driver
- SSD1683 display driver
- Front light Driver
- BQ27441-G1 battery fuel gauge driver.
Also remember, the whole point of the touchscreen is to add a virtual keyboard so book lovers can type in their book server's URL on the final device. I'll have to at least do 1 and 2 on the above list before I can implement a virtual keyboard. I'll probably also have to figure out partial refresh with LVGL. Either way, the future updates will be software focused as a bring up new components.
For the latest status updates please visit the project's Gitlab repository.
