EasyNixie is now available for purchase!
12/01/2023 at 23:31 • 0 comments -
First main batch is in production(500pcs)-sneak peek, better library documentation
10/26/2023 at 15:02 • 0 commentsA little update on how the project is going. The manufacturing process has began, here are some cool boards pics:) The first batch will mostly be distributed among Kickstarter backers, around 50 pcs will be available from Tindie and Elecrow around December.
I have also updated the github documentation with more comments and played around with Doxygen.
Just tested other nixie types(In-19b, z574m, zm1020)
09/16/2023 at 16:57 • 0 commentsEverything looks fine. Nixies with thin legs fit perfectly. Some digits are swapped but it is not a problem, since they can be swapped back in code.
Nixie Geiger counter
09/15/2023 at 15:12 • 0 commentsToday I have built a Geiger counter with nixie display using EasyNixie module.
The code is quite simple and can be found on https://github.com/allexoK/EasyNixie/tree/main/examples/Geiger_Counter
The better version of a counter that supports correct measurement units(uSv/H) can be built with some symbolic nixies(IN-15A and IN-15B). The IN-15B supports the 'S,' 'V,' and 'H' letters, while the 'u' sign is supported by IN-15A. The '/' sign can be created by rotating the '-' digit if using IN-15A by 45 degrees.
Just received another batch of Early birds/prototypes
09/11/2023 at 16:14 • 0 commentsThis batch was manufactured by PCBWay, the quality is really good.
PCBWay also sent me some extra unassembled boards which is nice!
I have also received some nixie tubes from my supplier:
Who wants to get their own EasyNixie?
09/08/2023 at 15:02 • 0 commentsThe Kickstarter campaign is now live, check out the early-bird reward option to get your own EasyNixie as fast as possible!
https://www.kickstarter.com/projects/esp32-stick/easynixie
The first mini-batch of final prototypes is here
09/03/2023 at 13:05 • 0 commentsI have received the first mini-batch of the prototypes. Everything looks good so far.
Checkout the comma:)
Next week the Kickstarter campaign will be launched, keep your eyes open if you want to get a super-early-bird (There will be 5 pairs of super-early-birds only)
Waiting for the final prototype
08/24/2023 at 15:33 • 0 commentsThe final prototype/early birds should be here at the beginning of the next month. When they arrive, the mini-Kickstarter project will be launched so anyone interested can get some samples:)
Here are some older prototypes:)
allexoK
