Roller Mill - Mostly Printed
A roller mill for mixing things in cylindrical bottles. In my case, SLA Resin prior to adding it to the reservoir
SLA resin must be homogenized prior to use, and having seen print failures due to trapped air bubbles induced by shaking, I decided I wanted a roller mill. After searching in vain for a reasonably priced unit, I decided to take it upon myself to design and build one.
Requirements:
- Sized to accommodate cylindrical bottles ranging from 250mL to 1 L
- Motion of the bottle to include rotation about the long (X) axis, and cyclical 'rocking' (XZ plane)
- Ability to operate for a fixed period from 1-30 minutes with automatic shut off at the end of the cycle
- Manual speed control with speed sensor and display
- A complete/containerized system that requires only 110V AC and operator actions as inputs
- Optimize components and subsystems for available manufacturing technologies, namely additive manufacturing (mSLA and FDM), hand soldering, and wire harnessing done by manual crimping
- Preferentially use purpose-built COTS components to simplify construction and debuggin
Cutaway view showing geartrain
Portable Network Graphics (PNG) - 340.46 kB - 12/25/2024 at 21:27
Preview
Roller Assembly v67.step
Complete assembly in STEP format
step - 38.47 MB - 12/25/2024 at 21:25
Download
Short video of the rocking motion. Both the bottle rotation and rocking are taken from a single motor fed through multiple gear trains.
Graphics Interchange Format - 12.86 MB - 08/20/2023 at 21:21
Preview
Monish Saravana Kumar Divya Sundari wrote 09/07/2023 at 23:11 • point
Would it be possible to get the 3D Models for this file? and the exact motor used.
Wil Carver wrote 12/25/2024 at 21:28 • point
Fifteen months later... See STEP assembly in the Files area
