Chess Piece Redesigns!
A project log for Gambit
A robotic chess board
mark-austinMark Austin 02/11/2025 at 14:491 Comment
One of the main issues with our current chess pieces is that they are too light, causing them to repel each other whenever they get too close. While this isn’t a major problem—since the movement is minimal—it’s still an annoyance we wanted to fix.
Learning from Phantom Chess
We’re not the first to encounter this issue. Our inspiration project, Phantom, also faced a similar challenge. They solved their weight problem by adding a small steel ring to the bottom of their pieces and switching from plastic to wood—though this required a CNC mill.
Our Approach
We wanted to keep this project as home-build-friendly as possible. Not everyone has access to a CNC mill, so switching to wood wasn’t an option. Instead, we opted to:
Old Chess Pieces
New Chess Pieces
By increasing the size of all pieces and setting the infill to 100% on our Bambu A1 Mini, we managed to double the weight of each piece, significantly reducing unwanted repulsion.
Major Design Reworks
Guide for Printing
Magnet Fit Tolerance
        This test lets you fine-tune the diameter of the magnet hole to ensure a snug fit—tight enough that the magnets don’t require glue, but loose enough that they can be inserted without excessive force.
Printing Settings
Peabody1929 wrote 02/12/2025 at 20:46 point
One can buy a very nice wood or plastic, weighted set of pieces on Amazon for less than $20.  This could save you time, effort and even cost.
