AP33772 Library Release
A project log for PicoPD - USB-C PD 3.0 PPS Trigger with RP2040
Adding Power Delivery 3.0 (PD3.0) & PPS to our beloved RP2040 chip in Pico footprint.
centylabCentyLab • 09/03/2023 at 08:59•0 Comments
I think the library is now at a point where you can use it for most of your applications. As of right now, it feature:
Examples are included to cover most of the use cases that I can think of. Feel free to create an issue or comment here if you have any questions about your specific need.
Still missing the ability to edit Mask which will be updated soon. The library also does not support interrupt mode so there will be no self-feedback from the IC. I look forward to further testing.
GitHub - AP33772-Cpp
Tested with:
