Features
- PCM5102 I2S DAC
- 112dB SNR
- -93 dB THD
- 384kHz PCM
- TPA6130A2
- 138-mW output power
- >100dB PSRR
- 68 dB CMRR
- I2C Bus Control
- 0.96inch 160x80 color tft display
- 80x160 Pixels
- 4-Wire SPI
- ST7735S
- RGB 65K
- 500:1
- 300cd/m2
System Description
An tiny cool headphone amp with TFT base on RP2040
usb_sound_card.uf2RP2040 firmware. Audio works. Two buttons and display not work yet.uf2 - 79.00 kB - 12/21/2023 at 01:27 |
3D Model HeadphoneAMP.zip3D Stepx-zip-compressed - 11.83 MB - 12/20/2023 at 03:36 |
BOM_WP-2040T_HeadphoneAMP_WP-2040T_HeadphoneAMP_2023-12-19.xlsxBOMsheet - 9.85 kB - 12/20/2023 at 03:35 |
PCB_WP-2040T_HeadphoneAMP_2023-12-20.pdfPCB_pdfAdobe Portable Document Format - 449.86 kB - 12/20/2023 at 03:34 |
Gerber_WP-2040T_HeadphoneAMP_2023-12-20.zipPCB_gerberx-zip-compressed - 80.29 kB - 12/20/2023 at 03:34 |
This one is based on the rp2040 sdk, I just added the code for the TPA6130A2, the volume and screen part is not done yet. Uploaded the audio part of the firmware first, the code is being reorganized.
impressive design
you have the code for rpi on github?
