It's child's play to use ESPHome to configure the D1 Mini to operate the companion relay.
switch: - platform: gpio id: i_relay name: '${node_name} relay' pin: '${RELAY}' restore_mode: ALWAYS_OFF icon: mdi:hot-tub on_turn_on: - delay: 500ms - switch.turn_off: i_relay
This switch can be directly controlled by Home Assistant. When something turns the switch on, it waits 500 milliseconds and then turns itself off. I had the switch turn the relay off automatically to isolate that information to the D1 Mini. There's no need for any outside entity to know the implementation detail of how we're simulating a human button press.
The relay board has a red LED that lights while the relay is activated, but that only lasts for a fraction of a second. The D1 Mini on-board blue LED wasn't being used for anything, so I exposed it so that Home Assistant can turn it on and off. The idea is that pushing the button is momentary, but the recirculation pump then runs for some number of minutes. Home Assistant will turn on the on-board LED for the duration of the pump activity. Both LEDs will be somewhat visible through the enclosure without needing their own openings.
My previous water watcher project included a BME280 climate sensor as part of my sprinkling of climate sensors around my house. I configured 2 pins of the D1 Mini as I2C so I can do the same thing here. The sensor will dangle out the side of the enclosure on a few dupont jumper wires. (I might later change that to a BME688 sensor, which can also detect various types of gases, but that's still I2C.)
In addition to the remote controls that I'll describe in a later project log, I also wanted to have a physical button to activate things. That's mainly for testing purposes while I'm fiddling with things. This is not the same thing as the simple sort of button that can be used directly with the Navien unit. Instead, it will follow the entire path of handoffs, just like the remote buttons. Even though it originates on the D1 Mini with the relay, it doesn't directly activate the relay. It's detected as a GPIO binary sensor by both ESPHome and Home Assistant.
Although this is a work in progress, here's what the ESPHome configuration for the D1 Mini looks like today. Notice that a few values come via the ESPHome "!secret" mechanism.
# https://hackaday.io/project/192719-calling-for-hot-water substitutions: node_name: hotbuttonrelay RELAY: 'D1' SCL: 'D5' SDA: 'D2' LED: 'D4' BUTTON: 'D7' log_level: 'DEBUG' esphome: name: ${node_name} platform: ESP8266 board: d1_mini wifi: ssid: !secret wifi_ssid id: !secret wifi_ssid password: !secret wifi_password power_save_mode: high fast_connect: on manual_ip: static_ip: !secret hotbuttonrelay_ip gateway: !secret wifi_gateway subnet: !secret wifi_subnet dns1: !secret wifi_dns1 dns2: !secret wifi_dns2 logger: level: ${log_level} api: encryption: key: !secret hotbuttonrelay_apikey reboot_timeout: 60min ota: password: !secret ota_password switch: - platform: restart name: "${node_name} Reboot" - platform: gpio id: i_relay name: '${node_name} relay' pin: '${RELAY}' restore_mode: ALWAYS_OFF icon: mdi:hot-tub on_turn_on: - delay: 500ms - switch.turn_off: i_relay - platform: gpio id: i_led name: '${node_name} LED' pin: '${LED}' inverted: true restore_mode: ALWAYS_OFF icon: mdi:led-on # Local test button. This goes through the relay logic, so it's not an analog press of the water heater button. binary_sensor: - platform: gpio name: "${node_name} Button" id: i_button pin: number: '${BUTTON}' inverted: true mode: input: true pullup: true filters: - delayed_on: 10ms - delayed_off: 10ms i2c: sda: ${SDA} scl: ${SCL} scan: false id: i_i2c sensor: - platform: bme280 id: i_bme280 address: 0x76 update_interval: 60s temperature: name: "${node_name} Temp" device_class: "temperature" oversampling: 16x pressure: name: "${node_name} AirPr" device_class: "pressure" oversampling: 16x humidity: name: "${node_name} RHumidity" device_class: "humidity" oversampling: 16x # From the Arduino board definitions file # #define PIN_WIRE_SDA (4) # #define PIN_WIRE_SCL (5) # static const uint8_t SDA = PIN_WIRE_SDA; # static const uint8_t SCL = PIN_WIRE_SCL; # #define LED_BUILTIN 2 # static const uint8_t D0 = 16; # static const uint8_t D1 = 5; # static const uint8_t D2 = 4; # static const uint8_t D3 = 0; # static const uint8_t D4 = 2; # static const uint8_t D5 = 14; # static const uint8_t D6 = 12; # static const uint8_t D7 = 13; # static const uint8_t D8 = 15; # static const uint8_t RX = 3; # static const uint8_t TX = 1;
The D1 Mini was first produced a long time ago, and the pin labels reflect the Arduino style. That's very handy if you are using the Arduino IDE, but I am not. ESPHome can use the Arduino designations for a lot of things, but it confuses my tiny brain. It's harder than I expected to find the Espressif GPIO numbering of the pins. I finally found it by working my way through the Arduino IDE board definition files.
