1Step 1
Installing Embedis
Use the Arduino Library Installer :
Sketch -> Include Library -> Manage Libraries
Library Manager
Under "Filter Search", enter "embedis" :
Search for Embedis
and Click on the "Install" Button :
Install
Now you can explore the Embedis examples under :
Files -> Examples -> Embedis -> Embedis
Note Bene : The default example uses EEPROM only, and will only function on boards with support for internal EEPROM (i.e. Arduino Uno/Leo/Mega/etc.), or boards with support for emulated EEPROM, such as the ESP8266. There are specific examples for boards with different capabilities, such as the Arduino Due, that do NOT include EEPROM internal to the microprocessor.
Using EmbedisThe Embedis command line interface (CLI) uses familiar SET/GET/DEL commands for storing, retriving, and deleting key-value pairs in the persistant memory stores. For example :
``` set mykey somevalue +OK get mykey +somevalue del mykey :1 ```For more information on using Embedis, please see the -> Embedis WIKI
Embedis Development EnvironmentThe git repository includes a submodule for the testing framework and a branch 'gh-pages' for the development generated documentation. The recommended commands to use are as follows:
git clone {origin_url} embedis cd embedis git submodule init git submodule update git clone {origin_url} html --branch gh-pagesYou'll need a few tools to build the tests and documentation. These are commonly tools available for all operating systems so you shouldn't have too much trouble getting them installed.
CMake can create a typical Makefile as well as project files for Xcode, Visual Studio, and many others. Here's a quick start for Makefile users:
$ cmake . $ make && ctest $ make doc
Pattern Agents
