STLINK-V2-TYPE-C-R0.zip
First revision: Gerber + LCSC BoM + JLCPCB P&P files. Status: everything works properly. Assembly recommendations: Black solder mask, single-sided assembly, 1.2-2mm thick.
x-zip-compressed -
165.16 kB -
10/03/2023 at 13:59
Download
STLINK-V2-TYPE-C-R1.zip
Second revision: Gerber + LCSC BoM + JLCPCB P&P files. Status: everything works properly. Assembly recommendations: Black solder mask, single-sided assembly, thickness 1,2-2 mm. Improvements: higher transit current, better ESD and current protection, reduced size.
x-zip-compressed -
222.15 kB -
10/03/2023 at 14:18
Download
