ElecLab 7.4" 1280x400 Display with HDMI interface
This 7.4" 1280x400 HDMI display can be connected to an X86 PC and also has screw posts for mounting a Raspberry Pi, AIDA64 or Volumio
Many long strip displays are vertical. This 7.36" display is horizontal, so it doesn't require rotating the screen.
I found lontium's LT8619C chip, which has HDMI input interface, TTL/LVDS output interface and I2S audio output interface. It was great, so we added a few more models.
Because I need to integrate the capacitive touch screen, I chose a 150MHz Cortex-M4 control CPU with a USB interface. Brightness control is adjusted directly via a rotary potentiometer.
We are not familiar with the initial version of EDID. We selected several resolutions in the compatibility section, which will cause X86 PC recognition problems. In the next version, EDID only supports one resolution of 1280x400, which will not There will be problems. Fortunately, the selected CPU can upgrade the firmware via USB, which makes it easy to upgrade the released code.
This is the finished product:
https://www.amazon.com/dp/B09YJ37SBH
https://www.amazon.com/dp/B0BWSX4DVL
Later I came into contact with the more popular MIPI displays. We newly used lontium's LT6911C chip. It has 2 MIPI output ports and can drive 2 displays at the same time and make them have the same display content or split one left and right/up and down. Display interface, this solution is very good.
I designed a PCB so that it outputs 2 channels at the same time and can connect
7.84" 400x1280 portrait screen,
8.8" 480x1920 vertical screen
11.26" 440x1920 vertical screen
11.88" 320x1480 vertical screen
Combining the 2 channels can also connect to a 10.1" 2560x1600 display.
JPEG Image - 441.50 kB - 09/20/2023 at 00:33
Preview
Portable Network Graphics (PNG) - 1.02 MB - 09/19/2023 at 08:14
Preview
JPEG Image - 660.71 kB - 09/19/2023 at 08:14
Preview
JPEG Image - 479.49 kB - 09/19/2023 at 08:14
Preview
JPEG Image - 353.22 kB - 09/19/2023 at 08:14
Preview
View all 10 files
View all 2 project logs
