Very interesting long strip display application
10/09/2023 at 12:27 • 0 commentsI found an application that is similar to this long screen. I don’t know what kind of UI can be used to easily create such an interface.This foldable structure is also very interesting.
Wireless connection aida64 using old Raspberry Pi 2/3 and ElecLab 7.4" 1280x400 display
10/01/2023 at 12:31 • 0 commentsA user shared the modified shell, I have printed it out and assembled it as shown below.
This example is to use the old RPI2/3 to connect the display and turn on aida64 wirelessly, so that you can remove the second secondary screen but still enjoy the fun of aida64.
The full-color 2510 fan has arrived, and the lights change beautifully when it runs.
7.4 Inch 1280x400 Touchscreen
https://www.amazon.com/ElecLab-Raspberry-Touchscreen-Capacitive-1280x400/dp/B09YJ37SBH/ref=sr_1_10?crid=CN01QCOOJG9V&keywords=raspberry+pi+screen&qid=1696048811&sprefix=raspberry+pi+scree%2Caps%2C328&sr=8-10Display Case
https://github.com/eleclab-rpi/7INCH4_HDMI_1280x400/blob/main/7inch4_1280x400_Case_Type6_For_RPI.STLFan Case
https://github.com/eleclab-rpi/rpi_fan_case/blob/main/RPI3_HAT_FAN2510_DURE.STLAida64 skin
https://github.com/eleclab-rpi/7INCH4_HDMI_1280x400/blob/main/star%201280-400.rslcdRaspberry Pi 2/3
8x M3x14 screws
4x M2.5x20 screws
4x M2.5x8 screws
