New 0402 LED version
A project log for reDOT_smart
smart miniature (DIP6) 5x7 LED Matrix
alexAlex • 03/27/2017 at 20:10•7 Comments
Soldering the 0201 on double sided populated boards was a fail (see last log). But here is the solution: 0402 LEDs. The board will be with 300x390 mil a little bit bigger than the old one (300x340). But hope that the 0402 LEDs are easier to solder. And they are much cheaper also.
Yann Guidon / YGDES wrote 03/27/2017 at 20:28 • point
Is there a way to prevent the parts from falling ?
In the industry, I think they use different pastes with higher liquidus temperature for the bottom.
Can you try a temperature-resistant conformal coating before flipping the board ?
davedarko wrote 03/27/2017 at 20:43 • point
I thought they would glue the parts down first.
Yann Guidon / YGDES wrote 03/27/2017 at 20:45 • point
that's for the old, vintage parts likes 1206 or at most 0603...
AVR wrote 03/27/2017 at 20:47 • point
yeah, today's process's rely on capilary action of the paste and pad surface
K.C. Lee wrote 03/27/2017 at 20:58 • point
They glue down the parts on the bottom side while wave soldering for through hole parts. The solder surface tension for small light parts should be sticky enough on a second pass of the reflow.
Alex wrote 03/28/2017 at 09:27 • point
As far as I know, is it all based on surface tension. As already written here. But in my mnual process this is not enough. I think I move it it much when soldering the second side.
Alex wrote 03/28/2017 at 09:29 • point
some kind of coating or gluing could work if the coating/glue is heat resistant. But i am quite happy now with this 0402 version. So far didi not had that issue with 0402 LEDs.
