First Hackaday.io post!!!
The Concept: Upon returning to my idyllic suburbanite life after a long day's work, I wanted to feel more awesome. More badass. The solution? Fire and (electric guitar) power chords.
I found some high voltage arc generators (probably used for tasers maybe) that also ran off a 12 V supply, and tested the device with a bench supply. I worked, pulling up to 4A:
Step 2: I had to learn how to control fairly high current (max 4A) at 12V with an esp32. I made a prototyping board, a couple relays, a 12V to 5V converter, and the arc generator.
That worked out alright. It was then time to program an esp32 to be the ESPNow master controller, and to program the board above as the ESPNow "voluntary helper" (formerly "slave" per the ESPNow library). Random Nerd Tutorials was a gigantic resource in this project, and they are the creators of many, many helpful exp32 projects.
It's worth mentioning here- I was using a push-button board I made for the Master controller esp32, but it only had 3 buttons (as well as my first attempt at hardwarre debouncing). I also screwed around with the capacitive touch pins. Ultimately, I wanted to send enough different signals that I bought a Blackberyy BBQ20 board that had been modded to run on i2c (and many other protocols). It worked great, and allowed me to quickly set up man different firing options (e.g. the timings on how long the valve remained open, how long the igniter fired) hot-keyed to individual burners. It worked good.
Step 3: Since I wanted 3 pairs of two of these (to resemble walkway lights), there was no way I was going to make another 5 proto-boards. Additionally, the protoboards were far bigger than necessary. I made my first 12V relay board with standoffs to insert the esp32s. I'm sure there are things that could hae been done better, but I was happy with the small form factor.
Below: The schematic I made using EasyEDA (this is included under prtoject assets) and the board view
Here is a quick walk-thorough of the parts needed:
Step 4: It was time to use my embryonic Fusion 360 skills to design housing for the controller board and the spark generator. Please note! Capacitors would likely be helpful for voltage spikes (and were included in the original design) but I had no way to discharge them so I clipped them out.
Step 5: working out bugs- I am gonna put a lot here, a I ran into a lot of problems and I lay them out here in case somebody were to encounter something similar:
To be clear, it took forever for me to get from one working flame pooger to six that worked together. I encountered a LOT of problems, most of which were my own fault.
a. Air-fuel mixture: Propane (and i think all hydrocarbon fuels for that matter) do not combust in an oxidation-combustion reaction unless they have, well, an oxidizer. Typically, this oxidizer is O2 molecular oxygen that comprises 21% of breathable air. Propane torches typically have a simple carberator, which use the venturi effect to mix expelled propane with atmospheric air. I did my best to design the flame poofers so air mixed with the propane enough that the high voltage igniter would trigger the combustion reaction.Here’s the problem: the pressure at which the propane is expelled lowers each time I consecutively fire them. Why? LIQUID propane is in the tank under pressure, so gravity pulls liquid propane to the bottom, and GAS propane fills up the rest of the space. Liquid propane turns to gas at -40C, and the pressure of the tank forces some of the gas into a liquid state.
Now, every time the cannister fires, the pressurized gas is released into the atmosphere, which in turn lowers the pressure in the cannister as it tries to equilibriate with atmospheric pressure. When the solenoid valve closes and no more gas can be expelled, some of the liquid propane phase-transitions to gas. This requires energy, in the form of leaching heat from the metal cannister. As a result, the cannister gets colder each time it fires. This colder temperature decreases the energy in the gas, so subsequent poofs contain lower energy gas, which in turn means less fuel is expelled, changing the air/fuel mixture to a leaner (less gas) mix. Luckily, the poofers ignite better with the leaner mix.
It’s worth stating here, the air fuel mix of the poofers is ALWAYS on the rich side, even at it’s leanest. This is aesthetically good, but it also means the flames contain less energy, and are generally pretty safe. I could swipe my hand through the mix, losing some hair, but not seriously injuring my self. It also means it is hard for these to ignite anything I DON’T want ignited (like the wooden beams in my shop).
b. The arc generators: I originally housed the arc generators right next to the esp32 chips. Bad idea. When the high voltage arc is created, it stops the esp32 code running, but any open solenoids are still powered. This is typically evident by a burning pillar of propane that will not cease until I kill the power. Slightly unnerving, slightly awesome.
Below: The chip crashing and the valve open with terrifying fire erupting:
Step 6: The Code- I am not a software designer. I program when I need to and when it is fun. I have no doubt this code is horrible. That said, I control fire in my front yard, so it has done what I've asked of it : )
(Edit: I cannot seem to get the entirety of the code up, so I will place it on github and link back to it)
Here is the final product, right in time for Halloween!
