1Obtain PCB (gerber files included on this page)
Send the PCB's gerber files to any PCB manufacturer (JLCPCB, PCBWay, etc.) to have the PCB made and shipped to you. Should come out to around $8 for 5 PCBs.
2Buy components to populate PCB
Need 2N7002 SOT23 (x3), 2M 0603 resistors (x2), 9.1M resistor (x1), 0603 red LED (x1), CR2032 surface mount battery clip (x1), 1N4148 SOD123 diode (x1), 47k 0603 resistor (x1), 2.2k 0603 resistor (x1), 680pF 0603 ceramic capacitor (x1), 80pF 0603 ceramic capacitor [OPTIONAL] (x1). All components should be easy to find on digikey and most from even Amazon.
3Solder components
Use a solder iron with a fine head to solder the components onto the PCB. Recommend using fine tweezers for soldering the 0603 components (and the 0606 flashing LED) and lead free solder. Please make sure to solder in a well ventilated area or using a fume extractor! NOTE: For best reliable results it is recommended that you apply conformal coating to the top side components of the PCB (the side with the LED, transistors, etc) in order to avoid inaccurate readings that can result if these components get wet.
