1Step 1
Download the pacman.zip file
2Step 2
Unzip the file. It will have created a "pacman" directory with various ROM files:
- the pacman.1k file is the one that all of the other files are derived from
- pacman.5e is the character ROM
- pacman.5f is the sprite ROM
- pacman.6e, 6f, 6h, 6j are the program ROMs. Only the lowest 1kbyte of space is used
- pacman.7f, 4a are the color and palette ROMs
- pacman.1m, 3m are the sound ROMs
3Step 3
Drop this "pacman" directory into your ROMs folder for MAME, or wherever all of your ROMs are stored.
NOTE: you can also just drop the ZIP file into your ROMS folder.
NOTE 2: Be sure to save aside your REAL pacman ROMs if you have any FIRST.
4Step 4
Run Mame.
- Player 1 Up, Down, Left, Right will move the sprite, and change the indicator display
- Player 1 Start, Player 2 Start will change the sprite you're moving around
- F4 will bring up a color,sprite browser. Move your joystick left and right to change the color banks, and sprite banks. Move your joystick up and down to select the color palette used
Scott Lawrence
