Salt fix?
10/06/2023 at 12:11 • 0 commentsIf you're using a digital workflow for negatives, then the lifetime of the negative could not be an issue for you? Have heard that using a really strong sea salt solution can fix, but it's really really slow.
Developer strength
10/06/2023 at 12:03 • 0 commentsThe reason why I use stand developing for all developers, is on account of me having arthritis and muscles that lock up with use. So you could say the formula was arrived at for my needs.
Some of you need to do testing with different amounts of potato. Would be great to hear your feedback and have your help.
Removal of silver..
10/06/2023 at 12:00 • 1 commentAs noted in the Hacked news feed, there are still problems with silver ions floating around. They may be able to be extracted from the solutions. I know it can be done with fixer.
