1Cutting
The structure is to be laser cut out of 3mm MDF sheets.
Attached is the project's CAD from which you can then obtain the DXF files to cut and assemble.
https://drive.google.com/file/d/1_zag8vkyx8sZ5FavsVlX5JEDlbVufBNV/view?usp=sharing
2Assembly
Having cut the different structure components, based on the pictures presented in the project gallery, and the CAD, the assembly will be straight forward.
In addition, there is a short animation of how to build the whole structure in the previous link with the CAD files.
Each part fits in perfectly with its corresponding parts thanks to the castellated edges. No glue or tape will be necessary.
3Coding
Attached below is the Arduino code used.
4Connecting
Having the structure completed and the Arduino code, the components connection can be done by following the next pin out diagram.
Once components have been connected, store them inside the designated compartment located in the back of the main structure.
5Make your drinks!
Fill your glass containers with designated mixers and alcohol.
PS. by adapting the code you can add or create your own drink mixes.
1. Connect the machine to the current.
2. Turn the drink mixer on by pressing the switch on the back of the machine.
3. Explore the menu in the touch screen by pressing on the arrows of the corners.
4. Select your desired drink.
5. Sit back while the drink mixer works its magic.
6. Enjoy your drink!
