PDF decoding in javascript
A project log for Synchronize a PDF with a spreadsheset
PDFMerge
lion-mclionheadlion mclionhead 10/13/2023 at 05:072 Comments
Lions traditionally used ghostscript to convert a PDF to images.  It's now considered pretty germane.  For a pure browser program, the internet recommends PDF.js
https://github.com/mozilla/pdf.js
A few chatgpt prompts can create a quick demo of how to draw text on a PDF.  For editing, you want the PDF in a persistent canvas & all the text in another canvas, with the 2 composited in 1 step.  Then, the user can alter a text element without redrawing the PDF & every other text element.
The next trick was reading a goog sheet.  There's a diabolical process to get a service account key.  Then a GPT demo using curl was a fail.  GPT can generate another solution using node.js.  They generally involve many steps to create an API key & download an access token.  Helas, the GPT says accessing a goog sheet directly from a web app requires making the sheet public.
At best, it would require hard coding the service account key in the javascript or a javascript include, but if curl can supposedly access it, a very simple web server on another port could just do spreadsheet queries with its own copy of the service account key.  Any solution is going to require a simple python webserver in that case.
The glaring problem is any insertion or deletion in the spreadsheet won't be reflected in the PDF overlay.  It's almost easier to make a spreadsheet program from scratch.  There are so many javascript spreadsheet programs, it might be a favorite toy problem of programmers.  Helas, they vary in features & bugs.
venskarr wrote 02/03/2025 at 16:01 point
Decoding PDFs in JavaScript can be tricky, especially when dealing with complex data structures. One approach is to parse the raw PDF content and map it to your spreadsheet logic. If you're handling data-intensive documents, like research reports or case studies, tools designed for academic formatting can offer insights. For example, a nursing essay writing service provides structured content that’s easy to analyze, which might inspire how you structure your PDF-to-spreadsheet synchronization. To streamline extraction and improve synchronization accuracy, focus on identifying consistent patterns in the PDF data—like tables or form fields.
mtalbotaa wrote 03/14/2024 at 09:30 point
Processing PDF files in the browser using JavaScript is quite an interesting topic. Thank you for the informative post. I'd also like to share a great online service that recently helped me a lot when working with text files. With the help of https://pdfguru.com/split-pdf I easily and without any hassle split the PDF file into several separate ones. It was very convenient and took very little time. Also, I want to note that this PDF maker works online on all platforms and doesn't require any additional setup, so feel free to use it, I think it will be useful to many.
