3d printed clamp
A project log for TIG Pedal for non-pedal TIG welders
This is a a simple solution to equip every welder, which does not have a pedal input, with a pedal to control the current.
cmaierhofercmaierhofer 10/14/2023 at 07:050 Comments
I 3d printed the clamp and it fits quite well. I think I will add a poti to limit the maximum current next to get the full range from 5 to max Amp of the pedal. Then I need to think about a housing for all of it. Perhaps I will put it inside the panel or onto the clamp itself or even build a small separate case to not put to much weight onto the knob.
