1Connect rotatory encoder to arduino micro.
Connect the pins of rotatory encoder to the given below digital pin input of the arduino.
CLK = 3
DT = 4
SW = 2
Positive to 5v
Ground to gnd
2Connect sound sensor to arduino micro.
Connect the pins of sound sensor to the given below analog pin input of the arduino.
SENSOR_PIN A0 to analog pin 0 (A0).
Positive to 5v
Ground to gnd
3Attach the steering wheel to the steering base.
Use the big gear ratio to match the low gear ratio and put the rotatory encoder in the low gear ratio.
4Attach joystick to the arduino.
Use the below given pin pattern to connect joystick as a manual gear box to the arduino.
Use the first pin as ground and connect it to gnd pin of arduino.
Attach all the other pins of joystick to digital pin 6, 7, 9, and 8.
5Attach pedal and buttons to arduino.
Use the negative points of the button and connect to the gnd pin of the arduino.
Use the positive pin of the button to analog pins A3 and A4.
Use the positive pin of the pedal to analog pin A2.
6Flashing the arduino.
Flash the arduino code provided in the project files and you are good to go.
7Game settings.
Install content manager for assetto corsa or any other game. Select the controller as wheel to sync the controls of the game. Select the controller as arduino micro and play the game.
