Using the TCRT5000 as a 3d printer auto bed levelling sensor
tcrt5000 abl-sensor carrier v1.0.stlsensor carrier release v1.0, has holes for m2 nut and screw for mounting (only tested on Cytron version, holes are included for the pins of the more common version)Standard Tesselated Geometry - 112.58 kB - 10/29/2023 at 12:34 |
sensor carrier v0.2.stlsensor carrier prototype v0.2, has holes for m2 nut and screw for mounting (only tested on Cytron version, holes are included for the pins of the more common version)Standard Tesselated Geometry - 112.58 kB - 10/29/2023 at 10:26 |
tcrt5000 abl.FCStdapplication/x-zip-compressed - 7.14 MB - 10/29/2023 at 10:26 |
sensor carrier v0.1.stlsensor carrier prototype v0.1 (only tested on Cytron version, holes are included for the pins of the more common version)Standard Tesselated Geometry - 112.97 kB - 10/27/2023 at 18:09 |
* Removed the 3 poles of the holes in the back that accommodate the pins of the more common version
* Adjusted the hole for the TCRT5000 head
* Moved the words to the bottom of the part
* Added a hole and a space for a nut to properly mount the sensor in the carrier
The carrier uses a M2x6 bolt and nut to secure the sensor inside. A washer can be made from cutting off a 1mm section of PTFE tubing. I stacked a normal metal washer on top, so the screw head doesn't just go through the PTFE washer.
I made a v1.0 after some more adjustments of the TCRT5000 head hole
Made a case for the sensor.
I plan on modelling a bracket later on and combining both the bracket and the carrier in the final version.
Pictured here is the v0.0.1 of the carrier, a v0.1 has been released which may or may not work with the more common version of the sensor.
