tcrt5000 abl-sensor carrier v1.0.stl
sensor carrier release v1.0, has holes for m2 nut and screw for mounting (only tested on Cytron version, holes are included for the pins of the more common version)
Standard Tesselated Geometry - 112.58 kB - 10/29/2023 at 12:34
Download
sensor carrier v0.2.stl
sensor carrier prototype v0.2, has holes for m2 nut and screw for mounting (only tested on Cytron version, holes are included for the pins of the more common version)
Standard Tesselated Geometry - 112.58 kB - 10/29/2023 at 10:26
Download
tcrt5000 abl.FCStd
application/x-zip-compressed - 7.14 MB - 10/29/2023 at 10:26
Download
sensor carrier v0.1.stl
sensor carrier prototype v0.1 (only tested on Cytron version, holes are included for the pins of the more common version)
Standard Tesselated Geometry - 112.97 kB - 10/27/2023 at 18:09
Download
