Finished soldering and received box to hold the sensors. Also made a handle to pull on the pressure sensors and finished connecting all 4 sensors with their cables to the arduino. This required a common VCC, GND and SCK (clock) pin with different DT pins for each sensor.
![](https://cdn.hackaday.io/images/1460971704808751771.jpeg)
![](https://cdn.hackaday.io/images/6106971704808751740.jpeg)
![](https://cdn.hackaday.io/images/5498141704808752569.jpeg)
![](https://cdn.hackaday.io/images/447781704808753744.jpeg)
Working on the code to get the 4 readings with each sensor and also to make sure we get 'w' 'a' 's' 'd' readings when a specific sensor is pressed.
