TSOC_NEOLED - LED Driver Embedded Module :
The TSOC_NEOLED connects any thingSoC (or Mikrobus) module to strings of programmable color LEDs. To the "Host" the TSOC_NEOLED appears to be a static memory of 2048 bytes, either I2C bus access (default), or SPI bus access for higher reads/write performance. Each color LED uses four (4) bytes of the memory as a 32 bit (eight bits each Green, Red, Blue, White/Yellow) word. The memory is organized as eight(8) strings of sixty-four(64) LEDs per string, by default. Other geometries can be programmed as well.- Supported by the Arduino IDE
- thingSoC Compliant Module
- Mikrobus Compatible Module
- Support Inidividually addressable RGB, or RGBY Color LEDs
;-) Tom
If you find this project useful, please consider supporting our Crowd Funding campaign at
http://bit.ly/2kkKddJ
we could really use your help and support - thanks!
@PatternAgents
Pattern Agents
TSOC_NEOLED with FTDI basic
TSOC_NEOLED with TSOC_USBUART2
PSoC Creator Bootloader Host
TSOC_NEOLED with Servo
YH-workshop
Laurynas Ubys
Reid Sox-Harris
