1Step 1
TSOC_NEOLED Arduino Sketch Examples
Under the "examples" directory are several Arduino IDE examples for using the TSOC_NEOLED board with Arduino IDE. Using the Arduino "Wire" library for I2C communications, it is simple to control the TSOC_NEOLED
// Start the Arduino I2C Interface wire.begin(); // Turn the first LED On (i.e. green LED #1) // the LED's are (GRBY) color order in memory byte row, column = 0; Wire.beginTransmission(TSOC_NEOLED_I2CADDRESS); // Start the I2C transaction Wire.write(row); // Send the high byte of 16 bit memory address Wire.write(column); // Send the low byte of 16 bit memory address Wire.write(TSOC_NEOLED_LED_ON); // Send a single data byte (we could send more...) Wire.endTransmission(); // End the I2C transaction // Turn the first LED Off (i.e. green LED #1) // the LED's are (GRBY) color order in memory Wire.beginTransmission(TSOC_NEOLED_I2CADDRESS); // Start the I2C transaction Wire.write(row); // Send the high byte of 16 bit memory address Wire.write(column); // Send the low byte of 16 bit memory address Wire.write(TSOC_NEOLED_LED_OFF); // Send a single data byte (we could send more...) Wire.endTransmission(); // End the I2C transaction
TSOC_NEOLED Programming
You can reprogram the board using any FTDI compatible USB to UART adapter :
TSOC_NEOLED with TSOC_USBUART2
TSOC_NEOLED with TSOC_USBUART2In order to reprogram the Cypress PSoC4 device, you will need to download and install the PSoC Creator tool, which includes a serial bootloader host application.
Select Tools -> Bootloader Host
Then select the hex (cyacd) file that you wish to program, and the COM: port of your device. Proess the "Upload" button to reflash teh device.
Other Applications
The TSOC_NEOLED can also drive other devices, such as Servos, Motors, Realys and more. This requires custom firmware at the current time.
Pattern Agents
TSOC_NEOLED with FTDI basic
PSoC Creator Bootloader Host
TSOC_NEOLED with Servo
