Badge to Eurorack
Frame/Adapter to make the Supercon 2023 Badge Eurorack compatible
there will be something here
Links
Repository of the Badge, if you want to build a badge:
https://github.com/Hack-a-Day/Vectorscope
@davedarko 's  red bootleg Badges: https://hackaday.io/project/8252-me-building-projects-from-hackadayio/log/224683-supercon-23-badge
  • 1 × Supercon2023 Badge
  • 1 × 3D printed Frame
  • 1 × generic blue LM317 LDO module
  • 1 × 4x6cm prototype PCB
  • 1 × 16p angeld box header
View all 11 components
  • First assembly test
    Alex • 11/05/2023 at 22:30 • 0 comments
    Not yet finished...but every thing fits mechanically. The empty prototype board is for the level shifting. You can also see the Eurorack Power connector on that. The Blue Module is al little LM317 LDO which will probably use to generate some supply voltage for the Badge. The Badge than gets powered via the SAO Header on the front. See also the red and brown cable on the images.
  • Basic Idea an some CAD
    Alex • 11/05/2023 at 18:14 • 0 comments
    The badge does have two inputs and two outputs, which can be seen as 0-3V Audio. So convert this to some more Eurorack compatible Levels (still not sure what are the right levels) and make them available on some 3.5mm audio jacks.  Than you need some cariiere to mount the Badge in your rack. This is what I cam up with:
    Front view of Carrier with four audio Jacks mounting for the badge. And a extended USB for update an other stuff. The USB extender is planed to be this: https://www.adafruit.com/product/3258
    On the back: Space for all the needed cables, some LDO module (front blue one) and a prototype PCB. On the Prototype PCB will be space for the eurorack power connector and some circuits for the level adjustment. The Badge will get powered via the LDO form the eurorack power. To connect the Power the SAO-Header on the Top will get used. The goal is not so change or solder anything to the badge itself.
  • First a Badge is needed
    Alex • 11/05/2023 at 18:03 • 0 comments
    As I am not attending this year's Supercon, I build my own badge. Boardfiles and BOM are available on this github: https://github.com/Hack-a-Day/Vectorscope and with some help of @davedarko I got my rebuild sourced, assembled and running.
View all 3 project logs
Richard Hogben wrote 11/17/2023 at 21:27 • point
nice one
