Not yet finished...but every thing fits mechanically. The empty prototype board is for the level shifting. You can also see the Eurorack Power connector on that. The Blue Module is al little LM317 LDO which will probably use to generate some supply voltage for the Badge. The Badge than gets powered via the SAO Header on the front. See also the red and brown cable on the images.
