The thingSoC Digital Programming Connector (DPC) is backward compatible with the industry standard six (6) pin "FTDI" pinout USB to Serial Adapter pinout. However, the thingSoC Digital Programming Connector (DPC) includes two(2) extra pins (RTS & DEBUG) for extended device programming, such as "NodeMCU types" which use the RTS signal as a programming Enable, and the DTR signal as a programming Reset.
thingSoC USBUART3 Pinout Diagram :
Pattern Agents
TSOC_USBUART2 to FTDI Six (6) Pin : Programming an Arduino Pro
Programming a TSOC_NeoLED Board
Programming a TSOC_RS485 Board
USB to WiFi Adapter
USB to RS-485 Adapter
USB to RS-232 Adapter
TSOC_USBUART2
TSOC_USBUART2
Sven Gregori
Vincent
Stefan Wagner
