fogmachine2.yaml
ESPHome configuration file for wi-fi fog machine
yaml - 1.02 kB - 10/31/2023 at 09:10
Download
halloweencontroller1.yaml
ESPHome configuration file for main Halloween controller board.
yaml - 5.98 kB - 10/31/2023 at 09:10
Download
Motion Sensor Enclosure Assembly - Top Cover-1.STL
Motion sensor enclosure top cover.
Standard Tesselated Geometry - 1.05 MB - 10/31/2023 at 09:07
Download
Motion Sensor Enclosure Assembly - Bottom Cover-1.STL
Motion sensor enclosure bottom cover.
Standard Tesselated Geometry - 768.15 kB - 10/31/2023 at 09:07
Download
Motion Sensor Enclosure Assembly - Lens 0.75-1.STL
Motion sensor enclosure snap-on lens.
Standard Tesselated Geometry - 89.54 kB - 10/31/2023 at 09:07
Download
Controller Enclosure Assembly - Gasket-1.STL
Rubber gasket for the main controller box enclosure designed to be printed on an Elegoo Saturn 2 with SuperFlex material.
Standard Tesselated Geometry - 4.86 MB - 10/31/2023 at 09:07
Download
Controller Enclosure Assembly - Bottom-1.STL
Main controller box enclosure bottom half.
Standard Tesselated Geometry - 613.95 kB - 10/31/2023 at 09:07
Download
Controller Enclosure Assembly - Top-1.STL
Main controller box enclosure top half.
Standard Tesselated Geometry - 438.17 kB - 10/31/2023 at 09:07
Download
Cauldron Handle.STL
Aesthetic handles to glue onto the sides of the cauldron. Print 2 of these.
Standard Tesselated Geometry - 4.75 MB - 10/31/2023 at 09:07
Download
Cauldron Quarter.STL
The cauldron body itself. 4 of these make up one complete cauldron. Originally designed to be printed on an Ultimaker S5.
Standard Tesselated Geometry - 4.94 MB - 10/31/2023 at 09:07
Download
