Tiny Backup Box
DSLR / Mirrorless camera SD Card backup using OpenWRT
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A backup utility similar to https://github.com/outdoorbits/little-backup-box, but using lightweight devices with built in batteries such as the RAVPower RP-WD03 or mobile routers (https://openwrt.org/toh/views/toh_battery-powered?datasrt=availability&dataflt%5BFlash%20MB%2A~%5D=). For backing up larger SD cards (>32Gb), you might want to consider something with a generous amount of RAM and a fast CPU. E.g. the RP-WD03 works, but backing up a 128Gb card can take a day or so.
