Simple Arduino Nano code for a LIDAR Range finder that sends distances to phone using HM10 Bluetooth module.
Lidar 1 (Power) to community Power
Lidar 2 to Nano A4 (orange)
Lidar 3 to Nano A5 (white)
Lidar 4 (Ground) to community ground
Lidar 5 to community ground (I2C Programming)
Lidar 6 Unused
Capacitor Positive to community power
Capacitor Neg to community ground
Bluetooth 1 Unused
Bluetooth 2 (Power) to community power
Bluetooth 3 (Ground) to community ground
Bluetooth 4 TXD to Nano D2 (Pin 2)
Bluetooth 5 RXD to Nano D3 (Pin 3)
Bluetooth 6 Unused
Battery Power to VIN (used 9V to test)
Battery Neg to community ground
Nano 5V to community power
Nano ground to community ground
#include <Arduino.h>
#include <Wire.h> // Instantiate the Wire library
#include <TFLI2C.h> // TFLuna-I2C Library v.0.1.1
#include <SoftwareSerial.h>
SoftwareSerial HM10(2, 3); // RX = 2, TX = 3
char appData;
String inData = "";
TFLI2C tflI2C;
int16_t tfDist; // distance in centimeters
int16_t tfAddr = TFL_DEF_ADR; // Use this default I2C address
int waitTime = 2000;
void setup(){
Serial.begin(9600); // Initalize serial port
Wire.begin(); // Initalize Wire library
HM10.begin(9600); // set HM10 serial at 9600 baud rate
void loop(){
if(tflI2C.getData(tfDist, tfAddr)){
HM10.println(String(tfDist/2.54)+" inches");
delay(waitTime);
I used BLESerialTiny for IPhone to connect to BT05 (the HM10 Module)
