28-Pin SOP Protoboard
Are you tired of struggling with spacing issues when using SOP (Small Outline Package) sockets on your breadboard? We have a solution!
0 followers
A New Era of Electronics Prototyping
Designed with precision and functionality in mind, our 224 tie point 28-Pin SOP Protoboard offers a seamless experience for electronic hobbyists and enthusiasts. Say goodbye to cramped spaces and hello to a board that allows you to unleash your creativity without limitations.
Key Features:
28-Pin Out Board: This specialized protoboard is tailored to accommodate SOP 8/16/28 sockets, providing ample space for your components to fit snugly and securely.
Dual Voltage Bus Lines: With power at your fingertips, the 28-Pin SOP Protoboard features dedicated voltage bus lines on both the left and right sides. This means you can easily distribute power where it's needed, ensuring a smooth and efficient circuit.
Labeled Columns for Enhanced Organization:
Columns A-E on the left
Columns F-J on the right
These labeled columns offer a structured layout, making it a breeze to keep track of your connections and components.
Why Choose the 28-Pin SOP Protoboard?
  1. Effortless Integration: Designed to seamlessly integrate SOP components, this board eliminates the frustration of cramped spaces, allowing you to focus on creating and innovating.
  2. Enhanced Power Distribution: The dual voltage bus lines give you the flexibility to power various sections of your circuit, ensuring optimal performance and stability.
  3. Streamlined Organization: With labeled columns on both sides, you can easily plan and execute your circuit designs with precision and clarity.
Take Your Projects to the Next Level
Whether you're a seasoned electronics enthusiast or just starting out, the 28-Pin SOP Protoboard is a must-have tool in your arsenal. Experience the freedom to explore, test, and innovate without the limitations of standard breadboards.
Get 70 (14 x 5) component terminals, compared to only (14 x 1)  on a standard breadboard when populated with the SOP socket.
  • 6 × Single Row Female Header 1X14 Single Row 14 Pins PCB Socket Female Header 2.54mm
  • 4 × Double Row Female Header 2x14-Pin Double Row Straight Connector Female Pin Header Strip
  • 1 × 28-Pin SOP Protoboard Printed circuit board
  • 1
    Integrate seamlessly into a breadboard setup
    1. Solder five 1 x 14 white single-row female headers to columns A-J
    2. Solder two single-row 1x14 red headers (male or female) onto the positive columns of the power bus.
    3. Solder two single-row 1x14 black headers (male or female) onto the negative columns of the power bus.
View all instructions
Bits4Bots wrote 11/04/2023 at 02:01 point
We have a design for ZIF sockets coming soon. How would you use these little protoboards?
