Display Enclosure V1 Assembly
A project log for ArduAOA
Use BLE enabled Arduinos to collect Angle of Attack (AoA) information and display
tklenketklenke • 11/20/2023 at 15:59•0 Comments
Following changes required to version 1 of the Display enclosure.
Holes in standoff etc work well for 2mm and at least a few turns of 2.3mm
Used 2x5mm for LED to enclosure and 2.3 x 10mm for two holes of the Feather/Wing to the enclosure.  Really need longer 12mm or 14mm.
Enclosure is serviceable as is.  See photos.  (Note: I did not yet install the side switch for power)
