As you can see in the gallery, I have one humble photo of my initial design for this computer. I have taken obvious inspiration from TechNIK's cyberdeck (found in the link section), as well as Carter Hurd's gaming cyberdeck build. I started off the design process with taking some measurements of my current 60 percent keyboard, and starting to lay out some shapes in the humble tinker cad. I initially thought tinkercad would be all I'd need to use to design this, but I have realized that it would take 300 years to do everything I want in tinkercad, so I'm going to have to learn some more complex software. Currently tinkercad words for getting the idea out of my head and into some kind of visual format, which is good. I have done my best to keep things to scale, however I'm going to need specific components to be able to make sure everything is proper.
