Introducing: MetaShunt V2
A project log for MetaShunt: High Dynamic Range Current Measurement
A low-cost and accurate tool for analyzing the power consumption of ultra-low power and IoT devices with rapidly changing current usage
jake-wachlinJake Wachlin 10/07/2024 at 12:590 Comments
MetaShunt V1 has been functional and available for a while now, and while it is still a wonderfully effective tool for examining the current consumption of a project across a wide range of operational modes, there were several improvements I wanted to make. This led me to develop MetaShunt V2! Thank you to my early customers on Tindie - your feedback and bug finding has helped make the original MetaShunt and now MetaShunt V2 that much better!
Goals and Updates of MetaShunt V2
MetaShunt V2 was developed to fix or improve a few key features of the original MetaShunt, as well as to add a key new feature:
First Look at the Hardware
MetaShunt V2 LT is shown below, with its new LCD display. Note also the additions of spring-lock connectors for the DUT, an improved shape, and two buttons. One button is used to reset long term data and the other is used as a trigger for burst measurements.
The base version of MetaShunt V2 is shown below. It has all of the features of the original MetaShunt along with significantly improved performance.
Interface Updates
Updates have been made to the open source MetaShunt Interface on GitHub. MetaShunt V2 is mostly backwards compatible with the original interface, but some changes were needed to support new capabilities. Specifically, check out the new realtime interface at Realtime Interface/metashunt_v2_realtime_interface.py. Also, check out the V2 version of the user guide for updates on how to use MetaShunt V2.
Available Now!
MetaShunt V2 is available now on my Tindie store here! Thank you for all the support from this community!
