GEVINO ZERO
GEVINO input output shield arduino ZERO LINbus power wifi bluetooth gsm sd tft
ARDUINO ZERO BOARD with 9A power output, 12v/24v input, lin bus driver, removable terminals.
GEVINO ZERO, Compatible ZERO M0 Arduino
CPU ATSAMD21G18 - Arduino ZERO M0 compatible.
Micro USB.
Pin to pin Arduino ZERO - M0.
Removable Terminals.
VCC, Input, Output 7V to 30V
4 terminals, Digital Input /Analog Input
Digital input with LED, need to bring VCC.
Analog input 1V fs, 6.8V fs, 22V fs
4 terminals, Digital Input / Digital Output
Digital input with LED + Protection diode, , need to bring VCC.
9A Output Mosfet with LED (max 6A), protection diode. We advise you not to exceed 6A
Supply:
GEVINO board
unsoldered 5 block pins
unsoldered Right Terminal, male + female
Optional:
Right angle terminals
WiFi modem ESP-01 ESP8266
GSM modem SIM800L
Bluetooth module HC-09
RS232 DB9 module
LiPo Battery and Battery Charger
Ethernet Module
TFT touch
LIN Bus IC - Atmel ATA663211 – Need to be solder on the P
GEVA ARDUINO ZERO Schematic.pdf
Adobe Portable Document Format - 102.46 kB - 01/10/2017 at 08:39
Preview
GEVINO.ino
ino - 5.98 kB - 01/10/2017 at 08:39
Download
ArduinoGEVA.pdf
Adobe Portable Document Format - 477.46 kB - 01/10/2017 at 08:38
Preview
