Printed key caps (using keycaps.pk2):
If a 3D printer does not support multiple materials, the final model can be painted by permanent markers. I found that the Sharpie felt-tip pens are durable and well-adhesive to PLA.
The model texture is formed by parallel lines (at side surfaces) or cross-hatched pattern on top and bottom ones, and the ink flows in those micro cracks, thus spoiling the painted regions. So I performed a trick:
- Made a model as if it is two-material.
- Setup a slicer for two headed printer having zero offsets.
- Removed all Tn commands in resulting G-Code text file.
Resulting model texture is having etched contours of inter-color borders, and the ink of different color don't intermix.
Keys "TGBYHN" are raised by 2 millimeters:
Here is the assembled keyboard from top (this time having full wiring):
I'll try, thanks. Is it paintable?
consider using xtc-3d as a coating on the keys. nice shiny smooth surface IMHO
