Suspension Tension Meter
Circuit designed to measure uniaxial forces acting on push-rods and transmit the collected data over the Controller Area Network (CAN) bus.
This circuit centers on the efficient STM32L4 microcontroller unit (MCU), orchestrating suspension data collection. The precision of the Suspension Tension Meter is attributed to the NAU7802 24-bit ADC, ensuring accurate recording of push-rod forces. Its high resolution captures subtle tension changes, aiding engineers in suspension fine-tuning. Real-time data transmission over the CAN bus enables adjustments during racing or challenging terrains, optimizing vehicle performance. The CAN interface serves as the data transfer backbone, facilitating seamless communication for real-time suspension adjustments, and enhancing handling on the track.
PCB manufacturing supported by JLCPCB:
https://jlcpcb.com/HAR
Author:
Ignacy Kajdan
Schematics and more:
https://github.com/PUT-Motorsport/PUTM_EV_SUSPENSION_TENSION_METER_2023
Suspension-Tension-Meter_Schematic.pdf
Full schematic
Adobe Portable Document Format - 268.27 kB - 11/19/2023 at 17:08
Preview
Suspension-Tension-Meter_PCB.pdf
PCB Layout
Adobe Portable Document Format - 48.40 kB - 11/19/2023 at 17:08
Preview
Dan Maloney wrote 11/20/2023 at 19:44 point
Interesting build. What are you using as a sensor? Load cells?
