TESTE28.zipThis sketch is quite extensive and a bit complicated. Obviously, it is not properly debugged yet. I've been working on it for almost a whole year, and it's easy to forget the operational details of certain parts. So, if you intend to test this sketch, keep in mind that a series of issues may arise. Problems with libraries and driver issues can be common when trying to use the TTGO processor for the first time. Therefore, I suggest starting with simpler things for an initiation. A good starting point could be a read-through of Jeroen Maathuis' work at:https://sites.google.com/site/jmaathuis/arduino/lilygo-ttgo-t-display-esp32/arduinomenu-demo-ttgo-t-display If you can reproduce the basic tests with the menu for TTGO, then it becomes easier to use my sketch. In the near future, I will clean up the sketch and list the libraries I used to make it easier for you to use. Zip Archive - 80.28 kB - 12/20/2023 at 17:55 |
