1Download the git
The git can be downloaded from:
https://git.ram.eemcs.utwente.nl/schoutenm/scanner_3D_printer_calibration
or
2Generate the gcode for the test pattern
Run "test_pattern_generator.py" using your favorite Python IDE. The code is written for a diabase H-series printer. If you are using a different printer you may have to change the settings in "calibration_pattern.py" for your printer.
3Print the calibration pattern on a piece of paper
Use the generated gcode file to print the calibration pattern. Be sure to use filament that has a large contrast with the paper that you are using. For example black filament on white paper.
4Scan the piece of paper with the calibration pattern
Scan the piece of paper with the calibration pattern using a flatbed scanner. Try use maximum resolution for the best accuracy.
5Analyze the calibration pattern
place the scan in the folder analyzer/example/data. Adjust the name such that the filename ends with the tool numbers followed by -1. Adjust the name of the file and the used tool numbers in "analyse_all.m". Then run "analyse_all.m".
Martijn Schouten
