The Idea
In a local shop I bought the cheapest (3.9 Euro) mechanical alarm clock I found, to scavenge the internal clock for this animated carousel.
However the casing was too nice not to be used in any other way.
So I decided to place an esp32-cam inside it with batteries, to be used as an extemporary webcam to watch kids, pets, cooking and so on at a distance.
The circuit
I composed the circuit using boards I had in my "wonder box", but they can be easily bought on AliExpress, EBay or Amazon.
Note the two 1 MOhm resistors, needed to reduce the battery voltage just to be measured by the ESP32 Analog to Digital Converter.
The assembly
See the positioning of the devices.
- The ESP32-cam board is fixed with some plastic foam glued to the chassis
- The TP4056 Battery Charger board has the USB charger socket back oriented
- The two batteries will be positioned on the bottom side of the case to lower the center of gravity.
- Bottom left there's a small optional antenna, found in an old WiFi router.
Antenna (optional)
It can be easily built with a small piece of tin. See here the specifications.
Time
OK, I got a beautiful WiFi Camera but I lost the main function for a clock! Therefore, according to a friend of mine, I used a NeoPixel 12 RGB LEDs ring to recreate hours and minutes.
The EspHome is programmed to:
- Flash for 1 second the red LED indicating the hours
- Flash for 1 second the green LED indicating the minutes (0 5 10 15 20 25 30 35 40 45 50 55)
- Stay blank for 1 second
- (repeat)
ESPHome programming
The YAML code is the following
esphome:
friendly_name: ESP32-CAM
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
# Enable connection to my home hotspot
wifi:
networks:
- ssid: !secret wifi_ssid
password: !secret wifi_password
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "Esp32-Cam Fallback Hotspot"
password: "Xy2wARLvmF24"
# Enable the WiFi info
text_sensor:
- platform: wifi_info
ip_address:
name: ESP IP Address
ssid:
name: ESP Connected SSID
bssid:
name: ESP Connected BSSID
mac_address:
name: ESP Mac Wifi Address
scan_results:
name: ESP Latest Scan Results
dns_address:
name: ESP DNS Address
captive_portal:
# Enable SNTP server time synchronization
time:
- platform: sntp
timezone: Europe/Rome
# enable the NeoPixel 12 LED's ring
display:
- platform: addressable_light
addressable_light_id: light_ring
width: 12
height: 1
update_interval: 1000ms
lambda: |-
// Define colors
Color red = Color(0xFF0000);
Color green = Color(0x00FF00);
Color blue = Color(0x0000FF);
Color black = Color(0x000000);
// set timing to be repeated every 3 seconds
int currentSeconds = id(sntp_time).now().second % 3;
int currentPos;
if(currentSeconds == 0){
// flash hours
currentPos = (id(sntp_time).now().hour + 12 - 4) % 12;
it.line(currentPos,0,currentPos,0,red);
}else if (currentSeconds == 1){
// flash minutes
currentPos = id(sntp_time).now().minute/5;
currentPos = (currentPos + 12 - 4) % 12;
it.line(currentPos,0,currentPos,0,green);
}else{
// clear everything
it.line(0,0,0,0,black);
# Enable ESP32 camera
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
# Image settings
resolution: 1024x768
jpeg_quality: 10
#brightness: 1
agc_gain_ceiling: 8X
# ESP32 Camera web server
esp32_camera_web_server:
- port: 8080
mode: stream
- port: 8081
mode: snapshot
sensor:
# Measure the battery voltage (3.7V nominal)
- platform: adc
pin: GPIO33
name: "esp32-cam battery voltage"
update_interval: 10s
accuracy_decimals: 1
attenuation: 11dB
filters:
- multiply:...
Guido - IW5ALZ
Vince
Dan Maloney
