Shift Register Menorah
A byte-sized wearable menorah pin with eight settable flickering lights
Starting from
$15.00
jsworkshop has 44 orders / 3reviews
Ships from United States of America
Shift Registers and menorahs are a match made in heaven: a shift register is a chip that remembers eight values, and a menorah is a lamp that commemorates eight days. This project seeks to combine them with simple control and minimal sacrilege.
IMPORTANT UPDATE:
Coin cell batteries are dangerous to children. More info below.
UPDATE:
Coin cell batteries can kill a child if swallowed. It is now mandatory that coin cell batteries be secured behind a secondary layer of protection. This design lacks that protection and it therefore should not be used. See Reese's Law for more information.
The Consumer Product Safety Commission regulation on this topic can be read here. More broadly, almost all simple coin cell holders lack a secondary locking mechanism, so many other products which employ them, even in a standard configuration, are in violation of  16 CFR Part 1263.
I'm leaving the rest of this post up as a notice to anyone who might be searching for similar ideas in the future.
Original post:
Using this menorah couldn't be easier. A single button on the front side just below the shamash candle serves as both the power switch and candle lighter:
  1. The first press of the button powers on the circuit and lights the shamash candle only.
  2. Tradition states that you now say the blessings before lighting the next candles. This menorah helpfully reminds you to say these blessings by introducing a short delay between the lighting of the shamash and when the circuit permits the next candle to be lit.
  3. The next button press lights the candle for the first night, which is either the rightmost or leftmost candle, depending on your perspective. Each subsequent press lights another candle in the correct lighting order: from left to right (again, perspective).
  4. All the candles can be extinguished by pressing and holding the button for a few seconds.
The Circuit:
Please note this circuit was cobbled together by an experimenting amateur. It could almost certainly be improved upon, but it works. And miraculously, it lasts for all eight nights on a single CR2032 battery!
You can experiment with it in the falstad simulator here!
There's also more details about the:
74HC585 Shift Register
MOSFET Power Latch
and
the actual board and schematic files
and
other design details!
Also there's now an assembly video for the kit version:
v2.1.brd
eagle board file
brd - 2.44 MB - 12/11/2023 at 21:31
Download
v2.1.sch
eagle schematic file
sch - 414.20 kB - 12/11/2023 at 21:31
Download
  • Prior Art
    Steph12/10/2023 at 00:38 0 comments
    I'm definitely not the first to have an idea like this! Here's a small sampling of other related  work that came up during my research:
    LED Menorah Using Shift Register
    LED Hanukkah Menorah
    Electronic Menorah Model II
    Menorah Soldering Project
    Menorah555
  • Can You Feel It Shifting In The Air Tonight
    Steph12/07/2023 at 02:40 0 comments
    Nice Bits!
    A shift register is perhaps most commonly used to drive a seven-segment display:
    It's the sort of display that you might find in a clock or in a DeLorean. Naturally, a seven-segment display does not actually have seven segments. Including the decimal point, it actually has eight. Which conveniently is exactly the number we need for a fully functional menorah! Of course, our shift register has a higher calling than blinking "12:00" on an some old VCR.
    The 74HC595 shift register used to light the LEDs in this menorah is located here on the left side of the board:
    How It Works
    The shift register has (basically) two inputs, and eight outputs. The two inputs we care about are "data" and "clock." For every pulse from low to high on the clock pin, the shift register samples the data pin, and shifts this value into the first slot on the register. Each of the eight slots are tied to eight LEDs.
    Unclear?
    Basically, think Skee-Ball:
    ...wherein each of these balls represent a high or low bit filling up the register.
    With every clock cycle, a ball is removed from the bottom, another is added to the top, and all the balls shift down. In this analogy, there are "on" balls and "off" balls, and these balls control our LEDs.
    In our circuit, power is first applied by pushing the button and activating the MOSFET. This immediately turns on the shift register, which actually powers on into an unknown, random state. Or if you prefer analogy: the Skee-Ball machine is filled with random balls.
    At this moment in time, when the power button has been depressed but not yet released, any of the 8 LEDs may be lit. As soon at the button is released, the chip clears its register and displays zero lit LEDs.
    In other words, the Skee-Ball machine flushes out all the random balls and refills itself with "off balls."
    From then on the data line is always high, meaning we'll be filling up our machine with "on" balls. Every time you cycle the clock by pushing the button, you are basically removing one "off" ball from the bottom of the Skee-Ball rack, and adding one "on" ball to the top.
    As demonstrated by Lisa and Maggie in the above gif, every "on" ball in the shift register causes a new LED to light.
    Once the register is full of "on" balls our menorah will be fully lit:
    At this point, additional clicks of the button continue to feed new "on" balls into the top of the register and the old "on" balls continue getting removed from the bottom of the register. None of this is visually apparent as all the lights on the menorah are already lit.
    To extinguish them, a long press of the button powers off the whole circuit. If you're playing by the rules, the candles should be put out thirty minutes after nightfall!
  • Latches on Circuits and Whiskers on Kittens
    Steph12/07/2023 at 02:01 0 comments
    Turn on the Light
    [Chorus]
    Bend me, shape me, any way you want me
    Long as you love me, it's all right
    You got the power to turn on the light
    -from the song "Bend Me Shape Me" by The Outsiders, 1966
    The push-on/hold-off functionality of this circuit is provided by the magic of MOSFETS. A MOSFET is just a type of transistor, which we use to control the flow of electrons between the battery and the rest of the circuit.
    Specifically, we use two MOSFETS to form a latch. In this configuration, the first MOSFET is activated by a switch, which momentarily turns on the circuit. This power activates the second MOSFET, which then performs the same function as the switch: holding the first MOSFET on. This means that one short push of a momentary contact button will hold the circuit on indefinitely. More about the specifics later.
    I (slightly) modified a latch circuit published here by Mosaic Industries:
    This circuit has one additional feature which is both a neat trick and also critical for our device to function: the button used for the main power switch can also be used to control other things once the circuit is on. This allows the use of a single button for both power and control.
    I replaced the dual MOSFET used in the original circuit with the SIA517DJ, which i chose for a few reasons:
    1. It's available in a tiny 2mm x 2mm SC-70 footprint.
    2. It runs on voltages down to 1.5v
    3. My supplier had them in stock
    It also has an on-resistance of a scant 0.17 ohms, so it wastes very little energy while doing its job. It also has a maximum reverse-leakage of just 1μA, meaning our battery will only drain a tiny bit while the menorah is off.
    Won't you P my neighbor?
    Let's take a closer look at the dual MOSFET latching mechanism. There are two types of MOSFETs, P-channel and N-channel. Both types have the same three connections to the circuit:
    1. Source
    2. Drain
    3. Gate
    Basically, in either type the gate controls the flow of electrons between the source and drain
    The difference between N and P types?
    A P-channel MOSFET turns on when its gate is low, while an N-channel MOSFET turns on when its gate is high. Our SIA517DJ dual MOSFET packages both types together, because they are often used together in a complementary fashion (see: CMOS).
    In our circuit, we use the P-MOS as the main power control switch, while the N-MOS simply serves to hold the P-MOS gate low, keeping the circuit latched on. Here's how it works:
    STEP 1:
    In our circuit, as soon as power is applied, the gate of the P-MOS is brought high. This starts the P-MOS in the off-state, meaning no power flows to the rest of the circuit. However, this gate is also connected to ground through our switch:
    Pressing the switch brings the gate low rapidly, and since a P-MOS turns on when its gate voltage is low, this instantly activates the P-MOS. Because our battery is connected at the source of the P-MOS, it will now flow through the P-MOS and into the rest of the circuit.
    STEP 2:
    As soon as that power starts to flow through the P-MOS, voltage at the N-MOS gate starts to rise. Here is the path it takes:
    Since an N-MOS activates with positive voltage, it now allows current to begin flowing. The N-MOS source is actually connected to ground, and its drain is connected to the P-MOS gate. As a result, any charge on the P-MOS gate will drain away to ground. Now, the P-MOS will stay on permanently, even when the switch is released.
    Now, the circuit will stay on, with the MOSFETs holding each other open, until the cycle is somehow broken. Which brings us to...
    STEP 3
    Our button is also connected to the N-MOS gate through a large resistor and a diode, which allows the gate to be drained slowly if the switch is held down. Holding the button discharges the capacitor through the resistor via the blue path:
    This combination...
  • Left or right? Where history and dyslexia meet!
    Steph12/06/2023 at 18:44 0 comments
    Determining the correct order and direction in which to light the candles is no easy task.
    And the internet is no help.
    When you begin this research you are met with many diagrams, but none of them are useful. In fact, the top results often contradict each other. As you can see in the screenshot below, the supposedly helpful arrows in these images are pointing every which way:
    Some of these diagrams have so many arrows they look more like football plays than lighting instructions:
    What I Know For Sure
    • The candle in the middle is called the shamash. It is always lit first.
    • Candles are added to the menorah day by day, and they are added from the right side to the left side
    • Candles are lit, using the shamash, from left to right
    This much we can agree on.
    Where It Gets Harder
    Ignoring the historical debates about lighting order, there remains considerable uncertainty about which side of the menorah appears lit on the first night. Take as evidence this ancient web image:
    The internet is again no help. A search for "hanukkah first night" returns images showing the first candle being lit on both the left and right sides interchangeably:
    One critical complicating factor is that menorahs are to be placed in a window, meaning left and right will appear reversed to viewers on the outside. The only place I found that adequately discusses this aspect is this youtube video, which includes this wonderful animation:
    ...and features as its top comment:
    At last a clear explanation of where right and where left is! Thank you!
    In the end, it's a matter of perception which depends on not only the vantage point of the viewer but also the behavior of the lamp lighter. Ask:
    • Whose perspective matters? The lighter or the observer?
    • Is the observer inside the house or outside?
    • When the lighter puts the menorah in the window, do they turn it around to face the observer?
    Whose Side Are You On?
    The more research you do on this topic, the less clear the answer becomes. As you can see from this post at stackexchange, rabbis and scholars have long debated the topic:
    Accuracy-smacuracy
    Truthfully, the ideal lighting order isn't really even possible when using a single button as the only interface.
    On day three, for example, the candles would be lit in this order (viewed from "inside"):
    ...but our pin (along with every other electric menorah I could find) lights in reverse of that- it starts on the outside and proceeds inward. To start in the middle and light outward, we would need a way to navigate to the third candle, which means we'd need a lot more brains in our circuit and probably at least one more button.
    Browsing other electric menorahs for sale, I saw no lamps which lit in that manner. Every one simply lights from one side to the other, some from left to right and some right to left.
    There appears to be no consensus.
    Of course by being three dimensional, these other lamps have much more flexibility. If you don't like the side they start lighting from, you can simply turn it around.
    Our pin is different: it cannot be turned around, therefore only one side can be presented. This makes the decision more complicated as unlike the other menorahs, ours has a canonical "front."
    I did find other example of a single sided menorah, but they weren't helpful either. This one doesn't even have the right number of candles:
    Another example of a single sided menorah is this virtual one - when you search on google for "menorah" you are presented with this interactive lighting animation:
    Note the small arrow above the leftmost candle. The animation doesn't permit you to light in any order but left to right, and you must start on the far left. By showing a menorah fully loaded with candles, it assumes we are celebrating the 8th day, thereby avoiding any further questions about left versus right or front versus back, as the candles are symmetrical.
    A Choice Must Be Made
    -or-
    It...
View all 4 project logs
metthewturner0990 wrote 11/27/2024 at 20:26 point
As an SEO Specialist, I’m thrilled to announce the launch of my latest project: https://thespykegame.com/! 🚀
This website was built with a focus on speed, functionality, and search engine optimization to ensure it stands out in today’s competitive digital landscape. Every aspect, from design to content strategy, was crafted to enhance user experience and improve search rankings.
If you’re looking for someone to create a fully optimized website for your business, blog, or personal project, I’d love to help you achieve your goals. Whether you need a site tailored to your specific needs, I can deliver a platform designed for success.
Let’s connect and take your digital presence to the next level!
#SEO #WebDevelopment #DigitalMarketing #WebsiteLaunch
jony jack wrote 04/06/2024 at 04:28 point
FIFA Mobile Mod APK is one of the best games that provides players unlimited money, coins, gems, and many more with unlimited fun and without any cost.(https://fifamobileapkmod.com/)
jony jack wrote 04/06/2024 at 04:26 point
<a href="https://fifamobileapkmod.com/">FIFA Mobile Mod APK</a> is one of the best games that provide players unlimited money, coins, and gems with unlimited fun and without any cost.
rasimorefashions wrote 01/06/2024 at 08:46 point
Nice!
Ale o co chodzi wrote 12/28/2023 at 11:41 point
this is not menorah ;P
menorah have 7 light
Ken Yap wrote 12/28/2023 at 11:52 point
That's probably because it's a https://en.wikipedia.org/wiki/Hanukkah_menorah I didn't know the difference until I looked it up. Haha, it looks like traditionalists? don't like this, or acknowledge that it exists.
powiadam.ci wrote 12/28/2023 at 19:32 point
chanukka != menora
Ale o co chodzi wrote 12/30/2023 at 15:54 point
David Grindel wrote 12/24/2023 at 04:02 point
I'd like to build a couple for my friends.  I thought I ordered  2 or at least put an order in, not sure I completed it.
Marcrbarker wrote 12/21/2023 at 15:41 point
I think the best part of the work is it uses an actual shift register and it's not based on a microcontroller.  A micro would of course have the lowest possible component count etc.  and give the exact same appearance - but wouldn't work the same on the inside.
Hey a workaround for the sense of direction: make a 'handed pair' and wear them as ear rings
Steph wrote 12/21/2023 at 18:51 point
Thanks Marc! The earring suggestion is a tidy solution :)
And of course I agree that ICs are just neat :) A microcontroller would be able to do so much extra stuff too: special blinking modes, auto-off timers, even handling the LED flicker with PWM. And therein lies the problem: how would I know when to stop adding features?
In my research I came across a menorah called the HanuKron (amazing name) that uses GPS to automatically light the correct candles just after sunset in your precise location. It's beautiful, but maybe automates some of the joy out of the celebration?
Marcrbarker wrote 12/21/2023 at 21:15 point
Something I've realized over a long career in design is there's so many different ways of making the same result. There's no such thing as a only one way to do it.
With the recent situation right now going on in Israel lately there's people who are taking more interest I guess that's what's caught my eye to learn more.
With a microcontroller can generate a psuedo-random flicker by coding a shift register function with a few feedback loops. I would make it easy for myself and have 8 separate groups of 3 registers...
Richard Hogben wrote 12/07/2023 at 20:00 point
Really entertaining read :)
