1Keyboard Disassembly.
The project commenced with a meticulous disassembly of each switch, involving a careful separation of components in order to lose any of the components.
2Lube the switch.
A thorough oiling process was undertaken, addressing both the individual components and the integral spring to enhance overall sound.
3Assemble the keyboard to the framework.
The switches were unskillfully reassembled, lacking precision at every step due to it being my first time.
The entire assembly was then mounted back into the keyboard framework. -
4Add rubber rings to Keycaps.
To further elevate the auditory experience, a decision was made to incorporate rubber rings onto each keycap
