1Install the Rasbian operating system to the Raspberry Pi with the SD Card
2Connect the Flight Aware SDR to the Raspberry Pi using the Micro USB cable
3Connect the 1090 MHz antenna to the Flight Aware SDR
4Configure the 3.5-inch TFT Screen to the Raspberry Pi
5Place the Device into the 3D Printed Case
6Ensure Python and Pip are installed on the Raspberry Pi
7Install dump-1090 FlightAware library on the Raspberry Pi to receive ADS-B information
The following tutorial is very helpful for getting dump-1090 installed on the Pi
https://www.stuffaboutcode.com/2015/11/raspberry-pi-piaware-aircraft-radar.html
8Run Radar Code
Clone the Repository on the Pi
git clone https://github.com/ANG13T/fly-catcher.git
Run the Program
python3 fly-catcher/device-rpi/piawareradar.py longitude latitude
Replace longitude and latitude with your geo-coordinates
9Download the Jupyter Notebook
git clone https://github.com/ANG13T/fly-catcher.git cd notebook jupyter notebook
Install Jupyter Notebook if you do not have it
Open up the localhost server at
http://localhost:8888
10Download JSON Flight Logs from Device
Visit the IP address of the Raspberry Pi device followed by the path
/data/aircraft.json
For example,192.168.1.114:8080/data/aircraft.json
